i am lookin to upgrade my memory to corsair xms to make my computer faster, and i thought it ran at pc2700 but looking harder on sites, i find its a pc2100!!
is this right?
is this slower?
will it run at pc2700?
and if so how? as i dont want to buy decent memory for it to only run at pc2100 anyway!!!
please help as pulling hair out, and feel let down by sony as on their sites they advertise new memory as pc2700!!!!
kind regards
marc
Crucial say buy 2700, and that's probably your best bet. At the very worst it will simply run at 2100, and maybe you will get lucky and find it's 2700. The cost difference will be minor.
thanx, is their anyway that i can find out just what speed my system does work at/ and will run at? as i want to buy xms memory from corsair as it runs quicker but it begins at pc2700 and i want to know if its worth it if i may only run at pc2100 anyway?:smileycry:
cherrs m8 will try and see what it comes up with:smileygrin:
It's not worth adding memory (eg Corsair) that responds well to overclocking to a Sony notebook because the timing settings aren't tweakable in the BIOS.
It's also to save overheating issues, which can't be a bad thing.
cheers again for the advice guys, it just seems as though sony make these things chuck in faster ram modules cos its cheap at the time then u think u can speed up ur machine, and u cant!!
regards marc:smileygrin:
Anyway....u will notice barely nothing using a 2700 DDR RAM instead of 2100.
So no need to "TWEAK".....
Tuning (or overcloacking) a system is done by using multiple combined tehnics as CPU, RAM, HD, Bus-Speed, Cooling V-Core and so on....
