Leaving Laptop turned on?
Leetay
Hi all
How many of you leave you laptops turned on 24/7?
Mine is basically a desktop replacement, so therefor never moves from the desk, and I have Acronis and Anti virus software running daily for back-ups etc.
Will it harm it if its left on constantly??
Ps monitor is set to go off after 2 hours, so that is not on all night, but everthing else, hard drives etc are.
12 REPLIES 12
kee-lo_
Simply remove the battery as you say it doesn't move off the desk anyway
jumpsuit
erm I meant just to test the batery's longevity? :smileygrin:
@5528097000005097
Don't forget your poor old hard disc, spinning away relentlessly! Still, with a working life of aprox. 20,000 hours, you should be ok for a few nights browsing (Jumpsuit could probably recommend a few good sites, by the sound of things)!!! :wink:
