Left Shift key +9 not working
papangdim
Hey there, I bought a vaio t13 ultrabook about a week ago and i just realised that when i press left shift + 9 the opening bracket, ie "(" does not appear though it works with the right shift key.
I also tried the left shift with all other combinations, i.e "!"£$%^&*)_+" and all seems to work perfeclty fine.
Note that i tried connecting an external usb keyboard and i got exactly the same behaviour ( this probably means that wiring is ok on my keyboard). In the mean time i will try and install a linux distro to eliminate the possibility of being an OS problem.
Anyone facing same problem? Any ideas/suggestions?
Thanks, D
heinthet
The same here,I tried changing the keyboard layouts,uninstalling the driver ,rebootng to safe mode but none of these seem to work,if had you fixed this problem,please let me know.. aheinthet1@gmail.com
