Mains adaptors
Metalman
Mains adaptors
Can anybody help explain the difference between the mains adaptor model VGP ac19v10 and ac19v3. Both are specified as o.k. for my VGN A397xp. Which do I purchase as a spare ?
34 REPLIES 34
kee-lo_
Yeah Rob did give a very satisfactory reply. I think you're going a bit far saying it was a waste of time.
I can understand why you're annoyed at the off topic chat, sorry about that
profile.country.de_DE.title
seb21__
Yes, sorry.
robpaxton
It's not a good idea to use a power adapter that has a lower power output than the one supplied with the notebook. The notebook will still try to draw the same current from the supply and it could cause system instability or a power supply overheating problem.
It is best to replace the supply with the same model (or equivalent) as the one supplied with the notebook.
Use a power supply with the same voltage but higher power output if the original supply cannot be sourced.
Metalman
Thanks for the straight answers
Jay1
well dont went to say much but would like to let you know that they could have made a better circuit and revtion but they normaly do this with the same model name. I would get the latest power supply which is recommened for the power supply. as said by ROB get the one with high current.
Circuit do change and you would not know this.
