Does anyone know if there's a firmware update available for the Matshita UJ-831Da optical drive (and if so, could I have the FTP link).
I have a VAIO FS215S and the original optical drive was replaced with this Matshita. Needless to say, it's not a standard part so no updates appear on VAIO Update.
I currently have firmware 1.01 and am having problems with some CD-Rs.
The problem is that the drive Sony replaced my original with is not used on the FS215S, so any updates for this drive won't appear in the list of updates I get for my laptop.
Which drive is it?
Which drive is it?
You will either need to contact support or search through other models to find which have this drive fitted and also have an update available.
