Hi there, whenever I try to play a dvd in media centre, or go online through it, it says it cant find a dll file, locks up and then restarts. When it realoads, it says that a serious system error was caused by a graphics driver.
I have a vaio vgn-fe11h.
Any tips, should I reaload with recovery disks?
Laptop is only 2 dys old.
Might be well worth doing a recovery.
Mine does the same! did you solve your problem???
A new video driver has been posted for this model on www.vaio-link.com:
Video driver version is 01.09.82.07
have you installed adobe premiere elements?
there is an update for this problem on the vaio support website
you have to install new dll's and the problem in your media center will disappear !
try it, you'll like it
