Memory Stick drive icon
mariocruz
[img][img]I have installed Windows Vista in my VGN-FE31H and everything seems to be working perfectly. There is just a little problem with the Memeory Stick Drive Icon. There is no true Memeory Stick icon. It is identified with no icon at all. What can I do to overcome this problem? I have installed all the Windows Vista necessary drives. :slight_frown:
Thalamus.
Champion
Hi mariocruz
Have you installed the MemoryStick Icon Registry patch from here
mariocruz
It seems that I have forgotten that specific one! It is solved now! Thanks!
Thalamus.
Champion
You're welcome mariocruz, glad your icon is restored.. :slight_smile:
