FE41Z Windows XP
edycom12
FE41Z Windows XP
Hi guys,
I recently bought a new FE41Z which comes with Windows Vista preinstalled. I want to format the hard disk and make a clean install of Windows XP, does anybody know how to get drivers for this very new laptop for its component but for winXP? Are the XP FE31Z drivers compatible? thanks a lot for the help!
edycom SPQR :cool:
Hi edycom12 and welcome to Club Vaio.
Why did you not buy the FE31Z which is exactly the same but with XP installed? It costs 400€ less !!!!
Seems popular though - have a look at these recent threads: -
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=39846
http://club.vaio.sony.co.uk/clubvaio/gb/en/forum/viewthread?thread=39210
Sony will not support your Vaio if you change the Operating System and you will not be able to revert to the old XP BIOS.
:thinking: :thinking: :thinking: :thinking:
