Memory upgrade! Help please
luis19martins
Hi there!!
I have a VAIO FS215S with two 256Mb memory modules, and I want to upgrade. Is there any way to install more than two modules of 512 Mb, like two of 1Gb? Or is it just not suported?
I would like some help! Thanks
Compliments!
Luís Martins
10 REPLIES 10
rich912
Hi Luís Martins and welcome to the forum.
Your model has a max memory size of 1 GB, so two 512 MB chips is the way to go….
Go n-éirí an bóthar leat
luis19martins
hi Rich!
Thank you for the help.
looks like 1Gb will have to be enough!! :slight_smile:
Do you think that there will be any problem if I upgrage to one module of 512Mb and one module of 256Mb?
Compliments.
Luís Martins
rich912
Hi Luís Martins,
This should not cause any problem as long as the two modules are compatible and have identical specification.
guerrillascribe
Good to know on the memory requirement. What's the best way of getting the pair of 512-meg chips?
I'm in Frankfurt, Germany, and really need the 1-gig of memory!
Most of us here order from CRUCIAL
However, Seb may be along a bit later and he may know a local source in Germany.
:wink:
robpaxton
Have a look at Crucial
luis19martins
Helo one more time!
Are this Crucial memory upgrades better than the Kingston's?
Regards
Luis Martins
Leetay
Hi, try these people too, cheaper than Crucial . com, and its Kingston they use
Lee
http://www.orcalogic.co.uk/asp/default.asp
Leetay
Lee
