Memory Upgrade in my Vaio FE21s
Nox2
Hi there. I have Vaio FE21s with this memoty type:
Storage capacity: 1 GB
DDR2 667 SDRAM
So-Dimm
533 MHz
HYS64T64020HDL-3.7-A
2x512 2Rx16
PC2-4200S-444-11-A0
And my question is can I put into this laptop this memory:
SAMSUNG
Specifications/Features
1GB
200-Pin SODIMM
Sixteen components (64M x 8-bit)
--->>****DDR2-667 / PC2-5300 ****<<--- in my is PC2-4200
CL5
Non ECC
JEDEC standard 1.8V +/- 0.1V Power Supply
4 Bank
Posted CAS
Write Latency(WL) = Read Latency(RL) -1
Burst Length: 4 , 8(Interleave/nibble sequential)
Programmable Sequential / Interleave Burst Mode
Bi-directional Differential Data-Strobe (Single-ended data-strobe is an optional feature)
Off-Chip Driver(OCD) Impedance Adjustment
On Die Termination
Refresh and Self Refresh
DDR2 SDRAM Package: 60ball FBGA -64Mx8
All of Lead-free products are compliant for RoHS
I want to remove both 512 and put in 2x1GB of above memory type.
Or maybe if it will be ok with thi better to buy this one:
Kingston New 1GB DDR2-667
PC2-5300 CL5 200-Pin SODIMM
Will it be OK? Can count for anwser from some expert here :slight_smile: :thinking:
tonybeard
Here you go and save some money too
