I've installed a version of Windows XP Pro (concrectly the modified Windows UE) and after install all the drivers, the MemoryStic icon have desapeared !
What can I do ? Thanks !
Hi Neme6
Download Msicon.zip (attached below), once downloaded extract the files place the snymsico.dll file into C:\Windows.
Finally double click on the both of the two .reg files.
This should install the MS icon..
