Problems with VGA output on startup
Jonaynay
Hello!!
First, sorry with my Englis... i'm spanish.
I have a Vaio VGN-N11S/W.
My screen its broken (cristal break) and i don't see anything.
The vaio runs ok, i plug a LCD on VGA output and its OK.
The problem its, when i need to restore o format the vaio... the VGA output dosent run in bios mode, only when windows boots...
I push FN+F7 to change to LCD but it dosent work.... only works when Windows its boots...
Can you help me?
Thanks a lot!
0 REPLIES 0
