As i can c from the specs the Rs Rz have the sam motherboards anyone know whether the motherboard is prescott compatable?? also want to upgrade my graphics cards to radeon 9800pro does my system have enough juice to power it? i have vaio rs402
cheers chris
I doubt it is
The Pentium 4 Motherboard range CAN accepts ALL P4 CPUs, regardless of weather your Processor has a Northwood Core, or a Prescott Core, as long as the pin setup is correct.
And also the ATI Radeon Series is awesome, your ATI 9800 OR 9800XT will only take up an AGP port (regardless of speed, whether 4x or 8x). The 9800 will not take any other slots or power supplies & if i'm correct, you should have 300W... MORE THAN ENOUGH!
ok cheers mate thats helped me alot !!!
chris xx
