I had to copy and paste that M:smileysad: I dont know what to do, it worked last night. This is awful, iM gonna have to send it away i think, well, it needs fixed anyway:smileycry:
Any quick fixes??
I guess you could remove the key and clean the socket which it is in...
how do i remove a key??
I usually put my finger under one corner and gentily push it up. Not sure if thats the correct way to go.
LOL, check your E-Mails hldomster.
There is a video for you. It will explain how you can do that.
i hjave removed the key and the button still types m, but i canty attach the key again, and the button isnt very sensitive
i think ive broken the key
i a ghoing to send the achine away
This machine seems to be a problem.....
