My "L" key gives me an upside down "L" in lowercase!!! Any ideas on how to fix this other than always use a capital!!!. All the other keys work fine!!!
The computer is a Sony Vaio Laptop PCG-F801.
Tim
Odd,
Try going to start>control panel>regional settings.
Otherwise check for spyware - with adaware and Spybot Search & Destroy
that is really bizzaa!! only thing i can think of is to change the regional settings as Kee-Lo say's,,,,,, never heard of this problem be4:smileyconfused: .....
Thanks Guys i tried the regional settings and it seems to have cured the problem. It now only happens in Microsoft Notebook. But my desktop home computer and my work computer all do the same so i guess that is a problem with the notebook software.
You mean Microsoft OneNote?
