My RX202 is very LOUD ...
shamrock105
My RX202 makes very loud noises , sounds like the cooler on the processor or the grapic card is vibrating a lot. Any ideas if a new cooler or graphic card would help or is there a simpler / cheaper solution ????
kee-lo_
Have you tried cleaning the fans and ensuring the fan is well fitted to the device?
