SONY DVD RW DW-U12A
Niels2000
SONY DVD RW DW-U12A
Type: SONY DVD RW DW-U12A
:cry: There are problems with burning on 1x- 4x DVD'S
I have had no succes with finding any firmware/Drivers to overcome this problem.
My Vaio PCV-RX502E
Is also not on the support list of drivers and hardware anymore.
Could anyone give me a link or upgrade for my DVD-R/RW +r/RW
So i can also burn 4X DVD with my 2.4.
I know the speed will be the same, but the way of burning is different.
Best regards.
Niels Haas:smileygrin: Email
kee-lo_
What software are you using and whats the error message?
Niels2000
Thank you for you reply,
i will make my problem clear, Its not a software program issue,
Seeing the old 2,4 DVD-/+r/RW work.
For the older DVD burners there is a Firmware upgrade to also burn DVD's that work with the new 4x Technology.
But for my DVD burner i can't find the firmware update, that should fix this problem.
i am using the last firmware version from the Vaio-link site,
But it is one of 2003
Best Regards Niels Haas
kee-lo_
