my sony vaio cr21s/l problem with sony cameracature utility
Nene89
please i have a problem with the camera capture utility. i just bought the laptop and used the program 3 times and it has stopped working. the version it uses is 2.7. please help me
knik777
your camera stops working or the utility does?
try to run other application such as 'skype' for example and discover if you camera work correctly. if so, perhaps, you have to reinstall your utility to make it workable.
hardboiledcop
I have the a motion eye camera in on my VGN-FE48E laptop. Whenever I use msm messenger or smart capure it cannot find my camera and says it maybe been used by another program. Has anyone else had this problem and how do I solve it.
I closed all related program in the task manager but it still wont respond.
