My Sony VAIO Duo 11 is not appearing on the official Sony support?
predbites
Hello all,
I have just purchased a second hand Sony VAIO Duo 11 and it's showing as some unknown divices in the device manager. When I download the drivers needed they will not install because they say they are not for this model but when I put the model number into the official Sony support website it can not find anything?
The model number on the sticker is: SVD1121Q2EB
Does anyone have any idea why this is not coming up in support, I do need the drivers and not sure where else to get them from.
rich912
I'm not sure why you are having a problem. Try the following link:
https://www.sony.co.uk/electronics/support/laptop-pc-svd-series/svd1121q2e
Rich
Go n-éirí an bóthar leat
rich912
Rich
