My Sony Vaio is not loading my profile
rsilesio
My computer is not loading my profile.
It is not a password error message. It is "it is not possible to load your profile". This happened after an error appeared when I did a previous log in and my windows was very strange. Unfortunately I just restarted my computer and did not pay attention in the former error message. The point is that there just my profile in my computer and I can't do anything. Any suggestions?
Regards,
rich912
Hi rsilesio,
Tap F8 at boot when you see the Vaio logo and select Safe Mode.
Open System Restore and restore to a  date when the login was working.
If this doesn't resolve the problem then a Registry edit may be necessary.
Rich
Go n-éirí an bóthar leat
4 REPLIES 4
rsilesio
The following message appears
Vista - The User Profile Service failed the logon. User profile cannot be loaded.
rich912
Hi rsilesio,
Rich
rsilesio
Thank you rich912. It worked for me.
I found this also.This is other find to solve if the boot doesn't work.
http://support.microsoft.com/
rich912
You're welome rsilesio - pleased to hear that it worked for you:smileyhappy:
