need foreceware drivers
Thomas-Haase
Hello.
I need the forceware drivers for my fs315h.
My notebook has a nvidia geforce go 6400.
Where can I find a place to download the forceware? On the nivida homepage is no download for go-cards.
Thanks for your help.
5 REPLIES 5
wytey
83.60
those should do the trick, I have the 315M and they work a treat
madhatter2426
did you have to modify any ini etc.
Thomas-Haase
Thanks. But don't you get any performance troubles if you use these modified forceware?
wytey
nope, I've had no problems with them what so ever. but define performance problems. As the Sony default drivers are old, those being much newer, they will naturally be better for performance etc.
I didn't need to modify the ini file, it went straight on.
Thomas-Haase
Thanks for the info.
Do anyone have a url or something for the latest vaio forceware? I remember so far it was 77.70 or lower.
