need help with my VGN-A397xp and what i got
RyanNicon
hi people i got my VGN-A393xp which is soooo nice
but i did't get any CDs with it should there be CDs with it? and if so how should i go about getting them?
the next prob i have is i can't Register it on the e-Support web site could any one help me with that
thanks guy i'm a bit lost at the mo
15 REPLIES 15
RyanNicon
its just i'v installed so much on it
kee-lo_
Thats no problem, it makes the DVDs from a hidden partition.
RyanNicon
oh right thats cool so if i formate the drive then put the CDs in with it put it back to like it was?
rich912
The restore process will format the C drive and return your system back to `as delivered¿ and you will lose any files or programs that you have installed or created.
Backup any data that you need before restoring!!!
Go n-éirí an bóthar leat
RyanNicon
ok thanks guy i'll try and get some DVDS i'm doing the CDs now all 9 of them but i'll use the dvds when i get them
thanks again
kee-lo_
No problem, good luck!
