Hi Lads, I have a question, I will put it in easy language as I am not technical when it comes to these things!!
My self and husband have laptop each, same room, my laptop is wireless,and husbands uses a wireless lan card! These are running off the router!
It seems the two laptops are getting confused, when using Ebay! and will put my username onto my husbands laptop, and vice versa!! What I need to know is, are the 2 laptops getting confused, because we are using one router, or in same room...
Told you I am not technical!!! so any answers please keep them as simple as possible....
