New one Harddisc in Sony Vaio VGN-SZ5MN/B
bmrjnst
I like to change the harddisc in my Sony Vaio VGN-SZ5MN/B.
Is it possible to use a novel one with a higher capacity volume and what I have to look for?
Thank you very much for your RE.
Regards,
bmrjnst
carloscerros
hi bmrjnst,
It's not so recommended to change OEM HDD on your unit if you want to keep your in warranty - if still.
Otherwise check in device manager what HDD is mentionned and try to find the same brand with more space.
profile.country.de_DE.title
itbroker
Bmrjnst,
Welcome to Club Vaio. :smileygrin:
Carlos Cerros is correct !
The best and cheapest solution is a new Mobile Hard Drive.
Take a look here...
Schone Grüsse aus Bayern (München).
