HI FRIENDS!
I try to link by Skype with my girlfriend. But I think there's no microphone in my Vaio S4. She has notebook Asus and the microphone is somewhere in her computer because I hear her perfectly.
Im not sure I havent microphone in Vaio, Is it probably switched off?
Hi Norman,
According to the specs it would appear that the S series does not have an inbuilt microphone...
They're bad quality, even for Skype anyway, you've dodged a bullet
Thanks. Thalamus and Kee-Lo, You helped me again!
Next time I'll use webcam to be closer to each other.
Well It's a good an idea!!!
Someone use webcam I'm sure. Is it conveniently? And by what programm do you connect?
If you have a modern VAIO they're in built, all you need is a headset
