since the end of october i can't watch TV on my vaio. The message is is: TV tuner unplugged, but the cable is plugged and i don't know wath i can do to fix it. Thanks for help.
Try to uninstall the driver and restart the computer and install again.. seem some minor problem on hardware checking..
Try to get the latest driver.. Although i am aware u can't get any new stuff on the vaio-link website.. have a try!!
thanks,but do you know where i can find the right driver?
It seems not to be in the folder with the Vaio driver on the harddisk.
