My K-Series laptop is about 6 months old and recently the LCD has started to flicker in an erratic "up and down" fashion nearly all the time.
Also some colours (mostly lighter) on the screen are fuzzy or look like the static you see on an untuned channel on a TV. Giving the screen a slight knock where it joins the main unit by the power light seems to fix the problem sometimes but it inevitably comes back once the lid has been closed and opened.
I am told this is very probably a loose LCD cable problem, which would make sense but I have been quoted almost £120 not including parts to fix this by an independent laptop repair centre specialising in Vaios.
Does my warranty cover this or something? The shop i bought it from do not take responsiblity after 1 month but instead gave me a phone number for Sony which didnt work.
Can anyone please give me a phone number or URL or anything, even tips or suggestions on how to solve this problem without spending a silly amount of money on something that should really be covered by Sony?
Thanks very much,
Ash.
Yes it's sad to see the VAIO having these problems
Wasn't that with the first GRX Rob?
Heh doesn't make good reading does it?
Guh,
Warranty expired the day I phoned them up, which was lucky as it was still covered. Was collected a month ago but had no change on the Repair status website or anything :S
Decided to hassle them with eSupport instead, Ill phone by end of the week but they quoted a 10 day turnaround on this :@
Your best bet is the telephone. Be polite but assertive and get them to escalate the repair.
I would give them another week or so then ask them for a replacement if they don't manage to repair it in that time.
Yeah I would ask again
I got mine back today, was a loose connection.
But, they also gave me a brand new battery, and, for some reason, a brand new DVD Drive... cant complain at that!
Thanks for the advice peeps, Ill let you know how it turns out
Sigh
eSupport started working today so I was on there quick as a flash checking my case details.
Appears they need to replace the whole LCD, and there simply arent any available
Left a note saying the thing was urgently needed and was a replacement out of the question if-its-the-quicker-solution :smileygrin:
Nerg
Hope they do replace the unit
