Hello,
I'm thinking about buying a new battery for my old VAIO PCG-SR1K because I use to work with it in university. My old battery runs for just 45min up to 60min
What's the approximate running time of a new PCGA-BP2S? How much is the difference to the 'bigger' PCGA-BP4S?
THX for all your answers :smileyblush:
OK, I found that the BP4S will run for up to 9.5h.
But what about the standard-BP2S in my VAIO PCG-SR1K? Is it worth the 90 EUR for a new one? I hope to get a running time of up to 5h, but I'm not sure. Any experiences?
Depends on how much time you need to be mobile.
If you can afford it get the extra life, be warned it aint cheap!
Phew. That's really excellent battery life I must say.
9hrs is incredible!
Hmmm... OK, thanks a lot.
I'll try for a new standard-battery or perhaps the BP4S (if there is a cheap offer). Everything is better than my old battery now
Good luck
