problem batterie with new sony vaio
moufdi
hi,
i have bought my vaio in junary, i have a problem with batterie when the laptop is down, the power go down even if the laptop is off, in 6hours, from 100% to 87% of power.
is use the pc in normal condition
Thks for help
j'ai un probleme avec la batterie de mon pc, meme s'il est etteint la batterie est consommé. pour test je l'ai etteint et apré 6heures la batterie est passé de 100% à 87%.
le pc est utilisé dans des conditions normal.
Merci de votre aide.
4 REPLIES 4
danielclark2
Hi There
If you go to control panel and Power Management make sure that you are running it on external power and not Batteries ??? this may Help.
Thalamus.
Champion
is use the pc in normal condition..
Hi moufdi,
Welcome to Club vaio, :slight_smile:
Do you notice this when starting your Vaio whilst using AC power or when starting with battery ..?
Dekesh
this sort of battery drain is usual when you start your laptop. My vaio reacts the same way. try using hibernation and the battery won't reduce so much during start up. but remember to shut down fully once in a while or so.
kee-lo_
When I boot the GRX on battery it uses around 7% of the battery
