Hi there
I cant get Bluetooth to work on my Vaio laptop. The bluetooth light shows from startup and then switches off when XP starts.
Whenever I try to create a new connection in Bluetooth settings i get the message: "Bluetooth not ready".
If i try the diagnostics I get "Check communication with Bluetooth Device - Fail"
Help
Hi g-spot and welcome to Club Vaio.
Have you enabled Bluetooth?
Turn on the wireless switch, double click the LAN icon in the system tray and select Enable Bluetooth Device, then click OK.
Thanks Rich912. That sorted it!!
No problem g-spot:smileyhappy:
