MY VAIO BUZZ EVEN IF IT'S OFF
davidestam
My Vaio VGN-FJ1S make a faint noise (I can hear if I get very closer to the back of the computer) like a buzzing EVEN IF THE VAIO IS OFF. Naturally if I remove the battery, everything make no sound. What do you think about that? Thank you for your reply!!!
4 REPLIES 4
dionisima
Io ho il tuo stesso problema con lo stesso pc, parli italiano? Sei riuscito a risolverlo?
Hi davidestam,
If you look back through this Forum, this has come up several times.
No-one has a solution - the faint buzzing seems normal, but it is a bit disconcerting.
It does not seem to cause any problems but, if you are worried, you can register your concern with Vaio-Link - just in case it does develop into a problem later.
:wink:
Josh-2552
it is the speakers. i have it with my stereo and desktop speakers. like you did, i unplugged the power supply and the noise stopped. it's normal, dont worry :tongue:
kee-lo_
