A problem has occured with my a115z. When you picked up the laptop and moved it, you could hear a component that was broken off slide over the bottom, inside the laptop. It also manifested in distorted images. Of which i have a screenshot, but not online. Of course i sent the laptop to sony for repair, but only the first problem seems to be repaired. The distorted images (my guess: the loose component damaged the VGA card, ATI 9200) remain. Anyone else had something similar???
I would send it back in, this is not good enough.
Um.......I would really say send it back to be safe. What the hell they are doing repairing the computer and then not switching it on to check they actually fixed it I don't know. A slight clip round the ear might be in order I think,
I bet they end up blaming DHL
What's DHL? It sounds like they just took out the thing that was sliding around and then sent it back :smileysad:.
The courrier Sony uses.
LOLTR, does doesn't it...?
Of course I will send it back. But I thought I'd post the problem on the board, maybe other users have had similar defects.
In Belgium uses EXEL as their courier.
