Problem with docking station
emitrom
I have just got hold of a docking station VGP-PRFE1 to use with my AR11S.
And unless I am missing something I think its broken! :slight_frown:
In theory I should just be able to plug in the power to the docking station then plug the laptop into the DS yes? There was no driver disk so I assume everything is standard?
The funny part is that Vista found a new USB hub and installed drivers for that but the in-use light has never come on and I am not getting any power from the DS to the laptop.
As well as no in-use light I don't get anything showing on Vista that acknowledges the DS has been attached. Which I think is a bad sign in itself! :cry: I was expecting some kind of docking icon to allow me to 'undock'. Or do I need drivers for Vista??
Maybe I am assuming too much that power comes through the DS to the laptop?
Anybody else had a problem with it or am I missing something? :thinking:
Thanks,
David.
Thalamus.
Champion
Hi David
Here is a link to the PREF1 manual: PREF1 Manual
Doesn't sound good.. :slight_frown:
Are you using the notebook power supply or the one supplied with the docking station to power your docking station.?
emitrom
Hi David
Hi Thalamus,
Thanks for the link its as useless ( the document itself ) as the one I have!
No it doesn't sound good does it?
I am using the power supply that came with the docking station which works fine with my laptop so at least that bit works!
I would have thought that the light comes on as soon as you plug it in maybe only when you use one of the ports??
Thalamus.
Champion
Hi emitron,
I would agree with you, I have a docking station with one of my older Vaio's and when the power lead is connected and switched on a AC power light glows..
