Problem with Processes!!
Ruud10
Hi all,
I am having trouble with my Vaio. When i first load up windows the machine starts to run slow. When i click onto task manager I find that it is running lots of processes. Any advice onto how I go about making a fix
11 REPLIES 11
profile.country.de_DE.title
seb21__
Have you checked your system for Spyware and Viruses? At the standard configuration, approx 40 processes could be normal.
Ruud10
yep checked for virus and spyware, however if anyone can reccomend free spyware download, i would be very grateful.
cheers
Pandamator
Free ANTI -Spyware downloads:
go to www.lavasoft.com and download ad aware personal
then i guess spywareblaster and spybot s&d are pretty good (look at donload.com).
Microsoft also offers a tool at their page so you might want to try this...
seb21__
Yep, the Microsoft AntiSpyware Beta seems to be a really scanner. I use it too. But I use Spybot S&D also.
rich912
As Seb said, a number of processes is normal, for example I have in excess of 50 running at present but the System Idle process is still over 85%. Have a look for any process that is using a large amount of the CPU.
Go n-éirí an bóthar leat
TygerTyger
Actually by pure coincidence my mum mentioned this the other day. When her computer started and the logon screen appeared, it kept saying '37 processes running' or something like that, even from a fresh boot. As far as I know, it's not supposed to do that unless some proper programs are running?
Is this what you mean, original poster?
seb21__
Yes. And programs like Virus scanners, the Microsoft AntSpyware, WLAN drivers, Personal Firewalls are processe which run in the background.
If you start your Computer in the safe-mode, then Windows starts only with the importants drivers. Less than 12-14 processes are not impossible.
And if you compare SP1 with SP2, then you can see that after SP2 Windows needs much more resources as before.
kee-lo_
My RA104 never really goes over 3% CPU usage unless I rip MP3, and then it's 50%, but if I encode a DVD, the HT kicks in and 100% CPU usage.
Then you hear my fans kick up a notch
seb21__
LOL, same here.
