S3XP hot, very hot
xied75
S3XP hot, very hot
Is it normal S3XP runs very hot, especially the right-hand side, both bottom and under palm-rest? What range is normal? How to tell if the temperature is ok or something wrong?
What kind of material was used for the case?
p.s. I can't find the following software in the App Recovery disc, so suppose I need to re-install one, do I need to do it by doing Sys recovery?
List of software I didn't find:
WinDVD5,
VAIO Launcher,
VAIO Recovery tool
4 REPLIES 4
Twisted-Rizla
Hi there.
Check to make sure there isn't a build up of dust on your fans. There's an article about overheating here.
Here's a link to some software you can use to monitor the temperature of your CPU.
kee-lo_
They're known to get hot, and Sony say it's normal :anguished:
Those programs should be on your recovery DVD
Twisted-Rizla
I borrowed an S3XP for a couple of weeks and could practically light a cigarette from the heat given off. Sony said that one was normal too
:laughing:
They should make a dry ice port for it. And the FS.
kee-lo_
Hahaha
I think it's selling as a hotplate laptop.
