Can anybody help please? 3 month old sony laptop, switched itself off and refuses to restart, no power, nothing, anybody know if this can easily be fixed or one for the warranty? Any help much needed and appreciated
mabye the Akku is defect. do u check it? or what is wrong exactly?
It seems to have no power after it switched itself off, no lights, i know the battery is charged and have tried it into the mains, still nothing,
and I dont know what Akku is, sorry for my ignorance
Many thanks for the reply
Go to VAIO Link, go to E - Support and Start a new case, they will be able to help you as your warranty is still valid.
Thanks very much for ur reply, I will try it
hey daver77,
is it solved?
if so how?
because mine (4months old) is doing the same stuff.
not powering up ...
