URGENT: No WLAN-Connection after BIOS-Update to version 7
roman_i
Hello,
I have FE11S BIOS from 6 to the last version 7 upgedaten.
Since till I can not get connection to my WLAN router.
Just before it was not any problems with BIOS version 6.
Is there any possibility to step back to BIOS 6???
Roman
:cry:
5 REPLIES 5
sweetCoffee
are you sure you haven't accidently clicked the little button on the right in front of your laptop to set off the wireless lan connection?? (it's right next to the bluetooth symbol on your laptop)
roman_i
Yes, sure...
I can see my Network name in the list of wireless networks.
I can not connext to them.
Now, I have tried to make a connection with netgear-wlan-stick.
It does work. Only the intern connectior is broken...
Roman
:cry: :cry:
tonybeard
Reinstall the Wireless Lan drivers from Vaio Link or delete the driver in the device3 manager and reboot and it will automatically reinstall
Thalamus.
Champion
Hi TonyBeard,
I have reinstalled WLAN - driver.
It does not help.
The connection would be established for a while
says windows and after this is it broken.
Any possibility to get BIOS 6 back?
Hi roman_i,
I think you may have to request bios version 6 from Vaio-link :slight_frown:
roman_i
Hi TonyBeard,
It does not help.
Thanx
