Program
jackzelouf
Program
Where is the program which tells you all the programs that were preinstalled on your vaio, and gives you the option to reinstall them.
Thalamus.
Champion
Hi jackzelouf
Go to Start > All Programs > Vaio Recovery Tool and click on Vaio Recovery utility.
Once the Vaio Recovery utility has loaded, click the options button and select Recovery Specific Applications that were pre-installed, click OK, then Yes and Yes again.
