I have a RA304 desktop and the power has failed. Does anyone know if there is an internal fuse and where it is located?
richard.a.king@btinternet.com
Sounds like it might be your PSU Richard.
How old is it?
The unit is 22 months old and came out of warranty last March. Someone has suggested that the PSU may contain a fuse which needs replacing. Would you know whether it does contain a fuse or am I likely to be acquiring a new PSU?
Any advice welcome and thanks for your earlier reply
I'd be very careful opening PSUs, as they can still hold a currant
I understand that and won't be opening the PSU if there is no fuse contained in it. But I am having difficulty with finding anyone who can confirm whether there is an internal fuse or not. do you know?
No idea, I'm sorry
