hi
I have recently purchased a ra104 complete with media a320 access point and the de30 converter.I have a z1sp notebook that is wireless connected to a bt2000 voyager that has one ethernet connecter and the ra104 has only one ethernet connecter. the ra104 media works perfectly well connected to the ethernet conecter on the computer.Has anyone managed to connect all of these together so that one can run the media centre and broadband adsl from the host ra104/204 via a router?
tapjor:smileysad:
You would probably need a switch or port.
Thanks Kee-lo
nice to be back , there is a spare pci slot would you think I could use this for either a ethernet port or better still would a wireless card be better. could bye a new router though! with switch in.
its a great piece of tech love it to bits.
tapjor:smileyhappy:
I think what you would need is a 4port ADSL router (wireless or not)
Thanks Kee-lo
I am part way their but still would appreciate any feedback from our vaio friends that may have put the media system and the broadband connection together on the RA104/204.
tapjor
Same here - for future reference :smileygrin:
Well Kee-lo
I have finally got all systems up and running with the purchase of a 3Com wireless router with 4port switch and a wireless PC card.
now operating with the ra104+a320+ de30 +z1sp
took some time but thanks for suggestion of a new router
i love it to bits.:smileygrin: :smileygrin: :smileygrin:
tapjor
No problem, glad you got it sorted
