RAM UPGRADE VPCSE1J1E
Jr.VAIO
Hello, I want to upgrade some components for my labtop (name: VPCSE1J1E, model: PCG-41414M):
I want to upgrade the ram of my labtop it has 4 gb of ram but I need 8 gb.
Where can I buy the ram?
Wich ram should I buy?
Does my labtop has capacity for 8gb?
How many slots does it have?
and should I get one ram of 8 gb or two rams of 4 gb?
I also want to know if I can upgrade the CPU
Is it possible?
Wich CPUs are compatible with my motherboard?
THANK FOR YOUR REPLY!! :yahoo::thumbsup:
Sean_Mc
Moderator
Hi again Jr.VAIO,
You could also check for compatible upgrades here.
Hope this helps.
Thanks,
Sean Mc
Sean_Mc
Moderator
Hi Jr.VAIO,
We'd recommend getting in touch with Sony Support for further advice on this.
Thanks,
Sean Mc
Sean_Mc
Moderator
Hi again Jr.VAIO,
Hope this helps.
Thanks,
Sean Mc
As Sean_Mc has said, look at the Crucial website here:-
http://uk.crucial.com/gbr/en/compatible-upgrade-for/Sony/vaio-vpcse1j1e
You will see that the motherboaard supports a total of 8GB of RAM in two slots of 4GB each.
Your Intel Core i5-2430M is a Sandy Bridge dual core processor and the top of the range  VPCSE1C5E has the Intel Core i7-2640M which looks compatible but I wonder if the upgrade is worth the expense.
