Hi Guys ... I've just bought the new Vaio VGN-T2XP and want to add a 512mb RAM card but unsure how to do so. On previous Model (PCG-T2) there was a separate flap underneath but nothing like it on this model. Any help much appreciated. Cheers
The memory slot is underneath the keyboard on this model.
You can find all information on how to install it here:
http://www.vaio-link.com/tutorials/memory/memory.asp?m=1818&l=en&ts=p60
Thanks Stephanius, not quite so easy as the previous model eh? 😉
Will go ahead and install it now.
