Random little space in my laptop, don't know what it's for?
tekp
Hi!
I'm using a VAIO VGN-CR11S laptop and I've noticed a space in the right hand side of the laptop near the front. You can sort of click a piece of plastic in and then it pops out and you can slide out a rather long rectangle of plastic to create a cavity in the side of the laptop..
I was just wondering what this is actually for.. :slight_smile: is it a remote control slot? If so where could I buy the remote from? :slight_smile:
5 REPLIES 5
Thalamus.
Champion
Hi tekp,
are you referring to the Express card slot, (see image below).. :thinking:
tekp
Yeah that's it, what is it? :S
Thalamus.
Champion
It's an Express card slot.. :thinking:
Your Vaio has an ExpressCard/34 (34 mm wide) slot, express cards can be used for a several things, for example wireless cards, soundcards, memory card readers, tv cards, etc.
tekp
Oh right cool.. :slight_smile: I didn't know if ExpressCard meant.. :slight_smile:
Could I get a remote control for my laptop to put in there?
Thalamus.
Champion
Not that I'm aware of.. :thinking:
