realtek driver for svf1532a4e
the sound was very quiet on my vaio even when i turned the volume up. i guessed it was an audio driver issue so  i unistalled the realtek driver but how do i re install the driver and which one should i install
rich912
Hi @spitfire17,
Assuming you are using the Windows 7 64bit OS then this is the driver you need:
https://www.sony.co.uk/electronics/support/downloads/Z0001333
Otherwise look here:
https://www.sony.co.uk/electronics/support/laptop-pc-svf-series/svf1532a4e?downloads-num=35
Rich
Go n-éirí an bóthar leat
i have Windows 10 64 bit OS
rich912
It doesn't look as though Sony are offering a W10 realtek audio driver so I suggest that you try the W8 driver:
https://www.sony.co.uk/electronics/support/downloads/Z0004067
If that fails to work you will need to search the Realtek Support site.
http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&Down...
Rich
