USB Jog Controller Utility / application... where can i get it?
danibrah5
Hello i have a Sony Vaio VGC-RM2U Desktop that came with a USB JOG CONTROLLER.
Since owning it i have reinstalled windows a few times and the recovery disks wont allow me to install the program, and i dont want to use it to re-write the whole installation but i cant find this application anywhere.
On the support website the application / utility just isnt there for download and i cant find it anywhere.
can anyone help me with this?
the jog controllers model is PCVA-JC1 if this helps.
Any and all help appreciated.
Thalamus.
Champion
Hi Danibrah5,
welcome to Questions & Answers..:smileyhappy:
Do you still have th Sony supplied recovery disc's, if so you may be able to re-install Jog Controller applications using those disc's..
6 REPLIES 6
Thalamus.
Champion
Hi Danibrah5,
Gerhard38
I have a similar problem: Sony Vaio Jog Controller PCVA-JC1. The original Vaio togehter with backup and installation media doesn't exist any more.
I connected the Jog Controller to a W732EN-Machine and the driver installs autmatically by Windows itself without problems and says, the HW is ready to use - but no action an the Jog Controller or buttons A-F moves the curser. I would like to get it operable for video cutting wiht Adobe Premiere. What have I to do - and whre can I get it?
Thanks, Gerhard
Hi Gerhard - I received your PM but will reply here for all to see.
Sony seems to have withdrawn support for Windows 2000 - I think all Jog Dial Utility software was for Windows 2000 or for XP.
I think you will find all the available software and updates here:-
http://www.driversforsony.com/update-sony/jog-dial-device-drivers-download/
I have no idea if any of it will install.
:thinking:
EDIT: Since posting, I have found some Jog Dial Utility software on this support page:-
http://www.sony-europe.com/support/en/content/cnt-dwnl/PCG-QR20/list
Gerhard38
First of all many thanks for your quick support.
Before I give the confusing multitude of software for "Jog Dial" a try a question:
On my hardware-part is written: "SONY PCVA-JC1 Jog Controller"; it looks like shown on this page:
https://www.manualslib.com/manual/250434/Sony-Vgc-Rm1n.html?page=56#manual
Your links point to two pages where I can only locate software for "Jog Dial" (not: "Jog Controller")
Jog Dial Utility - 6.21.05
JogDial Setup Files - 6.40.02.010702
Jog Dial Graphical User Interface Plug-In - 1.2.32
Do you think that "Jog Controller" and "Jog Dial" refers to the same HW? I faintly remember a page where there was a description of the differences between "Jog Controller" and "Jog Dialer", but I skipped it last time and now I cannot find it any more.
Now you mention it, I think the 'Jog Dial' was the hardware on notebook computers.The Jog Controller was a USB device for desktop computers.
You need the 'USB Jog Utility' and I can't find a Sony download quickly. There is no sign of it in the downloads for your model.
All I can see quickly is this:-
http://vaio-usb-jog-utility.software.informer.com/
but I can't vouch for the website!
I'll continue the search.
:thinking:
Gerhard38
Many thanks again.
The original desktop was a Vaio PCV-RZ72P, maybe this helps. It was shreddered in 2009 bc. of a defective motherboard . The USB Jog Controller still looked valuable and useful, but at this time I didn't need it, so I kept it any way for future use.
BTW, in the meantime I tried the JOG DIAL-software. Installation was possible, but it didn't make the Jog controller work.
