Recovery Discs for VGC-RA104
kumiasano
Hello,
I need to get hold of a full set of receovery disc for the above, can anyone help please?
rich912
Hi kumiasano,
To order a set of recovery disks you need to contact Support on the out of warranty number (from the UK the number is 0905 0310006 (Fixed: 0.35£/min)). Have your serial number to hand.
Rich
Go n-éirí an bóthar leat
nikkilim
Disks are usually purchased when it is out of warranty.
But try to check if the partition is on a separate drive other than "C". Sometimes, when you load a new OS, the partition drive is not written. Could be worth while to check on this first.
