Norton online backup and other trial junk
AndyZed
The request to start my Norton online backup trial keeps coming back to haunt me - how do you get rid of it? If there are any guides to getting rid of this and any other junk pre-installed on new Vaios please send me a link. Thanx
A
5 REPLIES 5
brjones35
Disable it in the startup programs
Thalamus.
Champion
Hi AndyZed
You should be able to remove Norton by doing the following..
Click Start then Control Panel.
depending on your operating system:
For Windows Vista, click Uninstall a Program.
For Windows XP, double-click Add or Remove Programs.
Select Norton Antivirus from the list of currently installed programs and then click Remove or Uninstall.
If you have a problem uninstalling Norton from your Vaio then you can download and run the Norton Removal Tool, use the following link to download: the Norton Removal Tool ..
flogger12345
Hi Andy. Go to Start - Control Panel - Add/Remove programs then uninstall anything that says "Norton" http://imagicon.info/cat/12-13/vbulletin-smile.gif
I think you will uninstall two softwares including the Norton updater.
Thalamus.
Champion
pctech33 wrote:
Online backup services are a good way to have an offsite backup, but you must have a local backup too especially with large files because it might take several hours to recover your data in case of a hard drive crash. I use MYPCBackup, the service is reliable and not expensive.
Guys,
you do realise this thread is over two years old & the orginal poster does not even visit these forums anymore..:smileyshocked:
pctech33
_______________
Life is too serious to be taken seriously http://imagicon.info/cat/12-13/text-smiley.png
Message was edited by: pctech33
