Hi!
I've lost the recovery disk of my Notebook Vaio...
I need to reset the computer...
Someone know how and who I have to ask to have another one?
I'm desperate! THANKS
Vaio Support and it costs ... lots!
Hi kekely and welcome to ClubVaio.
Have you ever formatted your hard drive? If not you may still have the Recovery Partition on your HDD. Try Start>All Programs>Vaio Recovery Tool>Vaio Recovery Utility.
What model of Vaio Notebook do you have?
Hi!
thanks...
the model is PCG-9L1M...
there isn't the possibility to create a recovery disk...
I can not find
but I have never formatted my hard drive before....
Hi kekely
In some cases the model number of a VAIO can be different from the chassis code number shown on the bottom or on the rear of the unit. If you click here does it show you a different Vaio model name...:smileyconfused:
This will help us to check the specs of your model..:smileyhappy:
Thanks Thalamus!
the result of the test is the following:
Your VAIO model name is PCG-FR315M.
Waiting for your suggestions....
thanks again
