recovery problems
shadow971959
recovery problems
help
windows failed to start recent hardware or software change might be the cause. to fix the problem:
1. insert windows installation disc and restart computer
2. chosse your windows language and then click next
3. click repair your computer
if you do not have this disc contafct your system administrator or computer manufacturer for assistance
status: 0xc000000f
info: boot selection failed because a required device is inaccessible
anyone able to help???????
profile.country.en_HR.title
toba18
I have same problem.Take litl program Hitman pro 3.5,scan you notebook for malware,and virus with them.And then tray .
Good luck.
