I keep getting norton ghost appearing on my screen how do i remove it and how do i create a recovery disc?
Hi baabaa,
Try Norton Removal Tool SymNRT 2007.2.0.5 to remove Ghost (download here).
To create your recovery disks click Star, All Programs, Vaio recovery tool and then Vaio recovery utility – follow the instructions.
Hi baabaa,
If it appears in
Start -> Control Panel -> Add/Remove Programs
then click on it and uninstall it there.
If it doesn't appear, try running the NORTON REMOVAL TOOL - this will remove ALL Norton Products from your system.
EDIT: Evening Rich !!
Thank you very much for the info:smileygrin:
Make a few copies - maybe one for the laptop bag too
